The Meta Quest 2 (formerly Oculus Quest 2) was released in October 2020 and is the successor to the Oculus Quest.
165 Questions View all
Is it possible to replace the charging port for the oculus quest 2
my charging port is broken and i have a bunch of friends on there and i love the quest 2 but its breaking the reason why the port is breaking is because i usually play while its charging meaning that its breaking it
Score 3
Add a comment
1 Answer
Chosen Solution
Hi Jack,
Yeah that part is definitely fixable; the good news is that it's a separate cable that incorporates just the headphone jack and the charging port so there's no soldering or specialized skills required to replace it.
Rather than repeat an entire answer, I'm just going to point you the the previous question where I responded with exactly the information you are looking for.
Can you fix the part that charges a piece is broken in it . - Oculus Quest 2 - iFixit
Sounds like you'd do well to pick up a couple of spares when you're ordering that charging port!
Good luck; let us know how it goes.
Score 2
2 Comments:
Thank you i thought that it would always be broken that just continued my yt gorilla tag channel
by
@jackmeren Excellent, hope you get it going again.
BTW, you might consider one of those charging cables with the magnetic head to use while you're playing; that way if you hit the cable it'll just pop off with no damage. Here's an example of the kind I'm thinking of.
https://www.aliexpress.us/item/325680153...
by
Add a comment
Add your answer
Jack Meren will be eternally grateful.
Past 24 Hours: 15
Past 7 Days: 128
Past 30 Days: 552
All Time: 10,095
