Repair Manual for Craftsman Riding Mower
How can I obtain a repair manual for a Craftsman Riding Mower?
Leon, download the manual from here. It has the user manual as well as the tractor repair manual in the back. If you are looking for something more specific, let us know. Any engine repair etc, will require the service manual from the engine manufacturer, i.e. B&S etc. Hope this helps, good luck.
Difficult to keep manuals online for 9 years. It is now posted on the bottom of this page Craftsman Riding Mower as "Craftsman_917_2736403_DYT 4000"
Need a manul for a Craftsman LT1750 Limited Edition riding mower with Koehler 17 1/2 power engine
Manuals Lib.com
log onto / Manuals Lib.com
need service & repair manual for craftsman tractor 917.258691
Need a deck for 917.272011
I clicked on the link “from here” and it takes me to “An error occurred while processing your request.”.
I get a "server unavailable"
Spring location on 2013 LT 2000 MTD 21HP I am interested in all information on this equipment thank you
@mklock3 Lamont Flores difficult to keep manuals online for 9 years. But it is now posted on the bottom of this page Craftsman Riding Mower as "Craftsman_917_2736403_DYT 4000"
Hi !
I need a shop manual for a Craftman tractor mower, 22 hp, hydrostatic, model 944.608240.
I have a problem with. When i push the shifter in front and that i pull it back in neutral, the tractor doesn't stop, and it does the same thing in reverse.
Could you send me the shop manual at:
takguy01@gmail.com
Thanks of lot.
Bertrand
I have a t140 craftsman riding mower.I took off the drive belt pulley assemble. I can not find how to put back on tractor. When I put together the belt will not disengaged with the motor running. I cannot the find adjustment on this t140 tractor. This only has two (2) pulleys NOT (3) pulleys.
This unit has left pedal which disengage the belt and brake. The right pedal only drive the unit. The more you push the pedal down the faster it will travel.
A shop manual will help a lot.
MTD makes many rebadged tractors including Craftsman. Search for craftsman tractor manual or MTD tractor manual and find one the looks similar. Most drive belt arrangements will be the same. My Troybilt has and idler pulley that tightens/loosens the belt. There are 4 pulleys, one on each blade drive, one on the motor and the idler. I can't picture how a 2 pulley system would work.
If you can't find a manual, you might also search parts stores for part diagrams.
Past 24 Hours: 14
Past 7 Days: 114
Past 30 Days: 643
All Time: 54,727
25 Comments
Depends on what model your mower is:-)
by oldturkey03
The model number is 917.2736403
Why would not all the Craftsman riding mowers have repair manuals available?
by Leon
I am sure they all do, but some off those need to be purchased through Craftsman and/or the dealers while others are downloadable.
by oldturkey03
why would oil be coming from the exhaust
by Leroy Swann
why would oil be coming from the exhaust on my LT 1500
by Leroy Swann
Show 20 more comments
