Samsonite Luggage Wheel Replacement
  1. Samsonite Luggage Wheel Replacement, Wheel: step 1, image 1 of 1
    • Clean the wheel to make sure that the wheel is not stuck.
    • Sometimes wheels don't work because they're caked with dirt or debris. This step can help you make sure that it needs to be replaced.
  2. Samsonite Luggage Wheel Replacement: step 2, image 1 of 2 Samsonite Luggage Wheel Replacement: step 2, image 2 of 2
    • Select the right replacement by measuring the diameter and width of the wheel.
  3. Samsonite Luggage Wheel Replacement: step 3, image 1 of 3 Samsonite Luggage Wheel Replacement: step 3, image 2 of 3 Samsonite Luggage Wheel Replacement: step 3, image 3 of 3
    • Remove the screws securing the wheel clip inside the case.
  4. Samsonite Luggage Wheel Replacement: step 4, image 1 of 2 Samsonite Luggage Wheel Replacement: step 4, image 2 of 2
    • Pull out the clip securing the wheel to the case.
  5. Samsonite Luggage Wheel Replacement: step 5, image 1 of 2 Samsonite Luggage Wheel Replacement: step 5, image 2 of 2
    • Remove the old wheel from the outside of the case.
  6. Samsonite Luggage Wheel Replacement: step 6, image 1 of 2 Samsonite Luggage Wheel Replacement: step 6, image 2 of 2
    • Insert the new wheel onto the luggage, making sure that the tubes on the wheel base align with the holes in the luggage.
  7. Samsonite Luggage Wheel Replacement: step 7, image 1 of 2 Samsonite Luggage Wheel Replacement: step 7, image 2 of 2
    • Put the clip back to its original position inside the case.
  8. Samsonite Luggage Wheel Replacement: step 8, image 1 of 3 Samsonite Luggage Wheel Replacement: step 8, image 2 of 3 Samsonite Luggage Wheel Replacement: step 8, image 3 of 3
    • Tighten the screws that hold the clip back in place.
Finish Line
6 other people completed this guide.
Xinyi Min
344 Reputation
1 Guide authored
26 Comments
Where can i get replacement wheels
ROBERT HAGGERTY - Reply
i have a samsonite luggage w 4 wheels can i change the wheels for 4 sets or 2 wheels each for easier rolling
ondinelewitinn -
Too limited in the range covered. Does not mention 6"x1/2" wheel replacement.
Angus - Reply
Super tuto pas à pas pour changer sa roulette ! Ce n'est pas compliqué de réparer une valise et tous les fabricants ou importateurs le savent bien. Le plus dur est de trouver les bonnes pièces... Mais nous sommes là :) https://jereparemonbagage.com
reprise - Reply
Too bad no mention of where to find the wheels. Amazon.com does not show the wheels I need and Samsonite webpage is NO help at all.
Dale - Reply
Past 24 Hours: 327
Past 7 Days: 2,271
Past 30 Days: 9,031
All Time: 228,003
