How to Replace a Guitar Nut
  1. How to Replace a Guitar Nut, Guitar Nut: step 1, image 1 of 3 How to Replace a Guitar Nut, Guitar Nut: step 1, image 2 of 3 How to Replace a Guitar Nut, Guitar Nut: step 1, image 3 of 3
    • Use a micrometer to measure the length, width, and depth of the guitar nut.
    • Use a ruler to measure the string height compared to the first fret.
  2. How to Replace a Guitar Nut: step 2, image 1 of 1
    • Remove the guitar strings.
    • If your intention is to replace the guitar strings; removing the strings by cutting them will be the most efficient.
    • If you want to keep the current strings; loosening then adjusting the strings will be the most efficient.
  3. How to Replace a Guitar Nut: step 3, image 1 of 1
    • Use a sharp knife to cut the glue from the edges of the guitar nut.
  4. How to Replace a Guitar Nut: step 4, image 1 of 2 How to Replace a Guitar Nut: step 4, image 2 of 2
    • Remove the original nut by striking it with a hammer or mallet.
    • Before knocking the nut out of its slot, make sure it was scored properly.
    • Inspect the location where the nut was removed. Use sandpaper to flatten the location if necessary.
  5. How to Replace a Guitar Nut: step 5, image 1 of 2 How to Replace a Guitar Nut: step 5, image 2 of 2
    • Sand the replacement nut, make the measurements identical to the original.
    • Only sand the nut a bit at a time. It's easier to work with a larger nut than a smaller one.
  6. How to Replace a Guitar Nut: step 6, image 1 of 3 How to Replace a Guitar Nut: step 6, image 2 of 3 How to Replace a Guitar Nut: step 6, image 3 of 3
    • Use a pencil to put graphite in the slots of the nut.
  7. How to Replace a Guitar Nut: step 7, image 1 of 1
    • Place the replacement nut onto the guitar.
    • Restring your guitar or move the strings back into place.
    • Do not glue the nut into place.
    • This step is to verify the measurements of the replacement nut.
  8. How to Replace a Guitar Nut: step 8, image 1 of 1
    • Verify the string height
    • String height is where precision is key. Make sure it is the EXACT height required.
    • Remove the strings before proceeding to the next step.
  9. How to Replace a Guitar Nut: step 9, image 1 of 2 How to Replace a Guitar Nut: step 9, image 2 of 2
    • Using watered-down wood glue, glue the nut onto the guitar.
    • Use a small amount of wood glue.
    • Placing glue on the guitar nut itself is easier than placing glue directly on the guitar.
  10. How to Replace a Guitar Nut: step 10, image 1 of 1
    • Restring your guitar or move the strings back into place. Tighten the string immediately afterwards to secure the nut.
Make sure the strings are tuned and the nut is in its proper place before claiming to be finished. It is important that the guitar nut becomes glued to the guitar properly. Be certain that the guitar nut is in place before, during, and after tuning the guitar.
Danylo Gula
181 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 101
All Time: 3,647
