How to Repair Trim On a Decorative Towel
  1. How to Repair Trim On a Decorative Towel, How to Repair Trim On a Decorative Towel: step 1, image 1 of 1
    • Choose a thread the same colour as the towel.
    • Use sewing scissors to cut a piece of thread about 18 inches long.
  2. How to Repair Trim On a Decorative Towel: step 2, image 1 of 1
    • Thread the string through the needle.
    • Tie a knot at the longest end of the thread.
  3. How to Repair Trim On a Decorative Towel: step 3, image 1 of 2 How to Repair Trim On a Decorative Towel: step 3, image 2 of 2
    • Flip your towel over so the backside of the towel is facing up.
  4. How to Repair Trim On a Decorative Towel: step 4, image 1 of 2 How to Repair Trim On a Decorative Towel: step 4, image 2 of 2
    • Starting at one side of the rip, insert the needle through the trim and then the towel.
    • Pull the thread through until it stops at the knot.
  5. How to Repair Trim On a Decorative Towel: step 5, image 1 of 2 How to Repair Trim On a Decorative Towel: step 5, image 2 of 2
    • Flip the towel over so the front side is facing up.
    • Insert the needle through the towel, then the trim.
    • Pull the thread through.
  6. How to Repair Trim On a Decorative Towel: step 6, image 1 of 2 How to Repair Trim On a Decorative Towel: step 6, image 2 of 2
    • Repeat steps 4 and 5 until you reach the end of the trim.
  7. How to Repair Trim On a Decorative Towel: step 7, image 1 of 3 How to Repair Trim On a Decorative Towel: step 7, image 2 of 3 How to Repair Trim On a Decorative Towel: step 7, image 3 of 3
    • Insert the needle through the back of the towel.
    • Pull the string through with enough length to create a small loop.
    • Put the needle through the loop and pull the string to tie a knot.
  8. How to Repair Trim On a Decorative Towel: step 8, image 1 of 2 How to Repair Trim On a Decorative Towel: step 8, image 2 of 2
    • Remove the needle.
    • Use your sewing scissors to cut the remaining thread.
Victoria Torkos
157 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 253
