How to Adjust a Garden Fountain Hose
  1. How to Adjust a Garden Fountain Hose, How to Adjust a Garden Fountain Hose: step 1, image 1 of 3 How to Adjust a Garden Fountain Hose, How to Adjust a Garden Fountain Hose: step 1, image 2 of 3 How to Adjust a Garden Fountain Hose, How to Adjust a Garden Fountain Hose: step 1, image 3 of 3
    • Turn off and unplug the fountain.
    • Remove the water from the fountain using a cup.
    • Empty the water into a bucket and place the bucket off to the side and out of the way.
  2. How to Adjust a Garden Fountain Hose: step 2, image 1 of 3 How to Adjust a Garden Fountain Hose: step 2, image 2 of 3 How to Adjust a Garden Fountain Hose: step 2, image 3 of 3
    • Remove the screws along the edge of the platform on the bottom half of the fountain using a Phillips screwdriver.
    • Lift the upper half of the fountain upward while holding onto the water pump.
  3. How to Adjust a Garden Fountain Hose: step 3, image 1 of 3 How to Adjust a Garden Fountain Hose: step 3, image 2 of 3 How to Adjust a Garden Fountain Hose: step 3, image 3 of 3
    • Lay the upper half of the fountain on a flat surface such as a table.
    • Remove the hose from the water pump.
    • Cut the hose an inch and a half shorter from the original length using a pair of scissors.
  4. How to Adjust a Garden Fountain Hose: step 4, image 1 of 3 How to Adjust a Garden Fountain Hose: step 4, image 2 of 3 How to Adjust a Garden Fountain Hose: step 4, image 3 of 3
    • Remove the screws at the bottom of the platform using a Phillips head screwdriver.
    • Remove the platform from the bottom of the upper half of the fountain and place the platform on the side.
  5. How to Adjust a Garden Fountain Hose: step 5, image 1 of 3 How to Adjust a Garden Fountain Hose: step 5, image 2 of 3 How to Adjust a Garden Fountain Hose: step 5, image 3 of 3
    • Loosen the clamp using a flathead screwdriver.
    • Slide the clamp onto the hose until the clamp is at the end of the hose against the surface of the bottom of the fountain.
    • Tighten the clamp using a flathead screwdriver.
  6. How to Adjust a Garden Fountain Hose: step 6, image 1 of 3 How to Adjust a Garden Fountain Hose: step 6, image 2 of 3 How to Adjust a Garden Fountain Hose: step 6, image 3 of 3
    • Place the platform on the bottom of the fountain.
    • Place the platform so that the holes where the screws enter are aligned.
    • Place the screws into the holes and screw them into place using a Phillips head screwdriver.
    • Attach the hose to the water pump.
  7. How to Adjust a Garden Fountain Hose: step 7, image 1 of 3 How to Adjust a Garden Fountain Hose: step 7, image 2 of 3 How to Adjust a Garden Fountain Hose: step 7, image 3 of 3
    • Place the upper half of the fountain onto the bottom half.
    • Align the holes where the screws enter.
    • Refill the fountain with water, plug it in, and turn it on.
Finish Line
Vivian Rivera
145 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 20
All Time: 61
