ExoPC Slate SSD Replacement
  1. ExoPC Slate SSD Replacement, Back Cover and Shield: step 1, image 1 of 2 ExoPC Slate SSD Replacement, Back Cover and Shield: step 1, image 2 of 2
    • Turn the PC on its back with the screen facing down and pull on the piece of plastic shown in the image. Use your fingernails to prod into the depression where the two plastic covers meet.
  2. ExoPC Slate SSD Replacement: step 2, image 1 of 2 ExoPC Slate SSD Replacement: step 2, image 2 of 2
    • Using the 00 Phillips screwdriver remove the two screws in the corners.
    • Using your left hand pull at the exposed section of the PC while simultaneously pushing the right with the thumb of your other hand. This will release the plastic clips allowing back cover to slide off, as shown from the picture
    • When removing the back cover make sure that the ribbon connectors going to the screen are not damaged. Carefully fold over the cover like a book.
  3. ExoPC Slate SSD Replacement: step 3, image 1 of 3 ExoPC Slate SSD Replacement: step 3, image 2 of 3 ExoPC Slate SSD Replacement: step 3, image 3 of 3
    • Remove the tape covering the metal shield.
    • Remove the 12 screws using the Phillips #00 screwdriver.
    • Dislodge the shield by pulling the prongs away from underneath the battery. The shield should come completely off.
  4. ExoPC Slate SSD Replacement, SSD: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Remove the two screws using the 0 Phillips screwdriver.
    • Gently pry the SSD from its connector using the tweezers, alternating each side of the SSD until it is free.
Jonathon Cronin
337 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 12
All Time: 411
