Joystick
1 Answer 1 Score |
Cannot reach the screw because the screw hole is smaller |
1 Answer 0 Score |
Logitech Gamepad F310 connects/disconnects |
1 Answer 0 Score |
My controller keeps disconnecting |
1 Answer 0 Score |
Is there a way to change the placement of the D-pad and left stick? |
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
Released in November of 2005, this USB controller follows a PlayStation-like design for PC gaming. It features 12 buttons, dual analog sticks, and an 8-direction D-pad.
Because this device is relatively old, there is not a lot of support available for this device anymore. Also, there is a newer version of this controller, the Logitech f310. The main difference between these two devices is the colorful front facing buttons on the f310, the variable press triggers, and the switch on the back to change the controllers input mode.
Identification
The model number (G-UF13A) is found on the label on the back of the controller.
Troubleshooting
For fixing issues with the device, refer to the Troubleshooting Page.
